Missing webhook_subscriptions.{read,write} scope for OAuth applications
I’m building an application that gets access with OAuth and it doesn’t seem like it’s possible to request the webhook_subscriptions.{read,write} scopes. I’ve tried both the scoped and classic OAuth methods.
Is the only way to setup webhook subscriptions via an API key?
Hi there Franklin,
You can also setup webhook subscriptions via website providing the following information:
  • Integration Name
  • Webhook URL
  • HTTP Method
  • Events to Send
Was this helpful?
  • YES :+1:
  • NO :-1:
0 voters
@xenda.amici Is it possible to set up the webhook subscription via API instead? Aiming to build an application where the user doesn’t have to do this manually
Hi @xenda.amici! Just wondering if there is an update on this thread, we are facing the same issue when trying to set up a webhook subscription via the API. We too are aiming to build an application where the user won’t have to do this manually. Thanks!
